i created a PAM file that contains the Key , crt , intermidiate
but when i want to use the SSL cert i get " ERR_TOO_MANY_REDIRECTS" on the browser
this is my configuration :
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
Web admin stats
frontend stats
bind *:8404
stats uri /stats
stats refresh 10s
stats auth admin:“XXXXX”
stats hide-version
Frontend_Here You enter all the Front Ends
frontend frontend_XXXX.com
bind *:443 ssl crt /etc/ssl/XXXX/XXXX.pem
acl ACL_XXX hdr(host) -i XXX.com
use_backend backend_XXX if ACL_XXX
Backend_XXX
backend backend_XXX
option httpchk GET /status HTTP/1.1
option httpchk
http-check expect status 200
option log-health-checks
default-server inter 5s fall 3 rise 5
http-check expect rstatus (2|3)[0-9][0-9]
cookie SERVERUSED indirect nocache insert
server iis1 192.168.11.85:80 maxconn 10000 check cookie iis1
