SSL Backend on Custom Port Causes 503 Error
hi
I want to send my ssl traffic to an ssl server on non 443 port and it causes
503 Service Unavailable
But If use same port on backend server for non-ssl traffic proxy works fine
also If I use 443 port on backend sever for ssl traffic still works fine
If I change config to SSL passthrough on same server and same port works fine
But ssl backend on custom port causes 503 error
It’s my haproxy.conf :
        # https://ssl-config.mozilla.org/#server=haproxy&version=2.0.3&config=intermediate&openssl=1.1.1k&guideline=5.6
        ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA>
        ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
        ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHAC>
        # Disable SSL Certificate Validation
        ssl-server-verify none
        # curl https://ssl-config.mozilla.org/ffdhe2048.txt > /etc/haproxy/dhparam.pem
        ssl-dh-param-file /etc/haproxy/dhparam.pem
        timeout client  50000
        timeout server  50000
frontend Listen443
        bind *:443 ssl crt /root/************/fullchainwkey.pem
        timeout client 60s
        http-request add-header X-Forwarded-Port 443
        # HSTS (63072000 seconds)
        http-response add-header Strict-Transport-Security max-age=63072000
        default_backend vp12
backend vp12
        timeout server 10s
        server ***.*********.*** ###.###.###.###:440 ssl verify none
I am sure that backend port is open and accessible from frontend server; just removing “ssl verify none” shows up server error that “You’re speaking plain HTTP to an SSL-enabled server port” so I am sure backend sever is accessible from frontend server
I can telnet to ###.###.###.###:440 (for ensuring that port 440 is open)
###.###.###.###:440 is accessible with browser
I also tried removing “http-request add-header X-Forwarded-Port 443” from frontend and add “http-request add-header X-Forwarded-Port 440” to backend but still not working
Sorry for bad english
It was a silly mistake
I should have use
" http-request set-header X-Forwarded-Port 440"
instead of
" http-request add-header X-Forwarded-Port 443"
in short term
add-header → set-header
probebly using it at the backend is a better idea
thanks
Make sure that you are listening on the port on the frontend
bind *:440 …
Also specify the same port on the backend
When you restart haproxy check netstat -na to make sure you are listening on port 440 (all servers) Where are you doing the SSL handshake at the frontend or the backend, you could get by with passthrough and keep the SSL handshake on the backend server, currently you are doing the handshake on the haproxy frontend
