I’m trying to configure and HAProxy to get HA to Kibana.
I’m using HAProxy 1.5.x although I tried as well with 1.6.3.
My config file is:
log 127.0.0.1 local2
maxconn 500 # Total Max Connections.
nbproc 2 # Number of processing cores.
timeout server 86400000
timeout connect 86400000
timeout client 86400000
timeout queue 1000s
listen http_web 0.0.0.0:80
option httpchk HEAD / HTTP/1.1\r\nHost:localhost
server server1 xxx:5601 maxconn 512
server server2 xxx:5601 maxconn 512
If I just have one server, it works, but when I have two servers it doesn’t response and I get and 403 error. I can only see the header of the web.
Checking the logs I get:
0000000c:http_web.clihdr[0008:000d]: Referer: http://xxx/app/kibana
0000000c:http_web.clihdr[0008:000d]: Accept-Encoding: gzip, deflate
0000000c:http_web.clihdr[0008:000d]: Accept-Language: en-US,en;q=0.8,es;q=0.6
0000000c:http_web.srvrep[0008:000d]: HTTP/1.1 403 Forbidden
0000000c:http_web.srvhdr[0008:000d]: x-app-name: kibana
0000000c:http_web.srvhdr[0008:000d]: x-app-version: 4.3.0
0000000c:http_web.srvhdr[0008:000d]: content-type: application/json; charset=utf-8
I have checked the log in the explorer as well
Failed to load resource: the http://xxx/elasticsearch/.kibana/index-pattern/_search?fields= Failed to load resource: the server responded with a status of 403 (Forbidden)
