Running Centos 7 HAP 1.5.18 We have the need to run multiple selenium grids and loadbalance the testing. Does anyone have an example config that they’re using with selenium and haproxy? If so it’s much appreciated. I’m getting very inconsistent results with testing.
Related topics
Topic | Replies | Views | Activity | |
Could Someone Give me Guidance on HAProxy Configuration for Load Balancing Web Applications? | 0 | 132 | June 26, 2024 | |
Global Load Balancing using Haproxy | 5 | 4432 | May 9, 2017 | |
HAProxy SSL Offloading high CPU usage on CentOS 7 | 0 | 793 | June 13, 2017 | |
HAProxy SSL Offloading high CPU usage on CentOS 7 | 2 | 2695 | June 20, 2017 | |
Global Load Balancing using Ha Proxy | 5 | 2696 | June 13, 2017 |
